what to do with my old block and pistons
Hi all, my blocks cracked so I need to either dump it or weigh it in. Is it worth anything up the scrappy?
Re: what to do with my old block and pistons
Will be worth next to nothing at a scrappy. Make a table out of it
as a rule iron/steel is around £100/140 per tonne so a block that weighs about 30/40kg is going to be worth a fiver.
Put some feet on it, stand it vertically and use it as a wine rack. You might want to clean it first, but you might not, your call
Spray it silver and sell it as a re-conditioned, then when they call you out get abusive and then pretend not to receive the engine back. Then wait for contact from Visa or Mastercard re-claiming the money.
Oh I'm sorry just make it into a coffee table.
What's the story with the pistons.
