After some much needed opinions/advice
I have a mk2 rev 1 turbo, which has just had a rev 3 head rebuild on it aswell as the ct20b turbo, ive also done some other mods but i am
going to replace the standard ecu managment for the rev 3 whilst changing to the rev 3 injectors at the same time, but im hearing that if i want any more than 300hp i should get an aftermarket ecu and re-map?
What if i was to get the rev 3 ecu management then re-map??
Please any help would be great.
Steve07
