My rev1 turbo tbar
gazrev1tubby
My rev1 turbo tbar
Post by gazrev1tubby »
Well folks, time has come for me to move on, and explore other avenues, so it’s with regret that my mr2 is up for sale.
I’ve owned her since May 2003, and bought it as a bone stock rev 1 turbo.
In my ownership, the its gone through various transformations, as most of you are aware, and I cannot stress enough at how meticulous I’ve been in caring for it.
It’s currently taxed until the end of October, but I may be forced to sorn it as the insurance is getting swapped to my new car. It’s mot’d until next May.
I’ve done an extensive list of modifications to it, some custom, but all my own work – at home.
Bear in mind, this car is not my daily hack, and only a weekend toy. I’d estimate that the engine probably hasn’t even covered 10’000 miles
The odometer currently reads 164'793 miles, but they're not the original clocks. It's covered around 110k miles, but I can assure you that the only part of the car that old, is the original shell !
Engine: (Revision 2)
Rebuilt in January 2011 with the following parts:
Wiseco 86mm 9:0:1 forged pistons
Eagle con rods
Clevite big end and main bearings, and thrust washers
Arp head and rod bolts
Rev3 metal head gasket
New oem oil pump
New blueprint water pump
New cam belt and tensioners
Head overhauled with valves reseated
I fitted a fully reconditioned ct20b turbo with a forge motorsport 0.9 bar actuator less than a year ago, that was overhauled by turbo rebuild in Birmingham.
It’s running a rev3 inlet manifold/throttle body, modified to suit the earlier head
Rev3 management and Fuelling conversion
Running 1.1 bar on bkr7e plugs
Gizzmo ms-ibc
Decat with support bracket
Phoenix power departure exhaust
Apexi induction kit
Ngk leads
Xs power style intercooler with block off plate
Walboro 255 lph fuel pump
Bored out xxxx rev2 fuel rail
Brand new Alloy radiator
The engine bay has been detailed, and partially wire tucked, done properly with the loom extended to the boot.
Drivetrain:
Stock E153 non lsd box that doesn’t crunch !
New drivershaft seals and and speedo drive
Techniclutch organic clutch
Brass shifter bushes
Chassis:
Both sills replaced at the beginning of this year, along with arches overhauled and wax oiled
Black bilstein suspension with ROC -30mm front springs, and Eibach -25mm rear springs
My own custom brake upgrade with Nissan 200sx s14a 4 pot front calipers with ferodo ds2500 pads and supra mk4 uk spec tt discs, with stock rev2+ rear calipers and mazda rx8 front discs on the back.
Braided brake lines
Trd anti roll bars with s-bits poly bushes
New drop links, track rod ends, and lower ball joints
Toms front strut brace
Body (Rev 1 t-bar):
Repainted in dark charcoal in 2010 (peugeot gris kazan)
FE front bumper
Border rear spats
Border side skirts
Aeroware front lip (Although I can supply a rev6 front bumper with the car)
Rogue rev6 headlights
Autopista rear spoiler
F40 style rear engine cover
Brand new autoart crystal front lenses
Custom rear centre panel with rare el glo badge
Single side vent mod, with carbon vent scoops
Bonnet gas rams
Carbon fibre scuttle panel
Carbon radiator cover panel
Interior:
Freshly retrimmed stock seats in black leather
UK leather door cards
Custom centre dash trim, with blue led gauges blended in (oil press, oil temp, volt)
Mk3 steering wheel
Rev3 shifter with genuine TRD leather gear knob
Heater control leds in blue/white
Uk rear foglight switch, with tell tale in stock uk location
Uk 160mph clocks, with Clifford l.e.d in stock location
L.e.d map lights
I.C.E:
Sony single din head unit
Vibe s.e.k 6.25 components up front, with tweeters
Vibe 4” co ax in rear stock location
Passenger side cutom sub box with Alpine 10” sub
Amps on custom board in frunk
Wheels:
SSR 5 spokes, repainted in black – but could do with a refurb
7 x 17 f with 205/40/17
8 x17 r with 20mm spacers 225/45/17
Other extras:
Data systems ‘factory look’ turbo timer
Rear lexan window blinds
Clifford Avantguarde 5.5 cat 1 alarm/immobiliser, with dual zone proximity sensor, anti lift sensor, complete with two fobs
Mirrors fold upon arm/disarm
I think I’ve pretty much covered everything, there’s bound to be a couple of things I’ve missed, but you see that it’s quite a car, with an extensive spec !
I have a folder full of receipts, and all the mot certificates since my ownership.
Bad points:
There are a couple of very minor ‘car park dings’ on the bodywork – as with almost every car on the road !
The drop glass trims have faded – as they all do, but I intend to touch them up with a bit of satin black
I genuinely can’t think of anything else off hand, that isn’t perfect. The ride quality is lovely, it handles really well, and runs perfect.
This is a very reluctant sale, and after writing this ad, I’m wondering if I’m making a mistake ! I will not sell it to any ‘tom, dick or harry’, I would like it to go to a club member, who will look after her and cherish her as I have.
Price is negotiable, but I won’t budge much, so no dreamers or anyone who thinks they’re going to get a bargain. Viewings welcome, but a test drive will only be granted upon proof of valid insurance for THIS vehicle. Also please note that the car may soon be sorned – due to dvla laws when a vehicle is no longer insured
The current number plate is my personal reg, this will be getting removed, and I’d assume the dvla will issue a replacemet ‘h’ prefix registration for the car. Please note, that it could be a couple of weeks until this is done
Price
£4295
turbo_87
Re: My rev1 turbo tbar
Post by turbo_87 »
Never thought you would sell this Gary, good luck with what's next.
Would like to add that this is one pampered and extremely well looked after car. The new owner will be very lucky to own such a perfect example of MR2.
gazrev1tubby
Neil, you and me both buddy, I have to say that I'm going to struggle seeing it drive away :cry:
Thanks for the kind words bud :)
But the next chapter in my life involves two turbos, in the form of a supra........... :thumleft:
les85
Post by les85 »
One of the nicest mr2's out there, I've always admired this one. Such a shame to see you selling mate . :(
GLWS.
Ethan21
Post by Ethan21 »
I spy a supra
Cant believe you are selling it! Why dont you brake it?
leonkehoe
Post by leonkehoe »
Post deleted by author.
steve_c
Post by steve_c »
Ethan21 wrote:I spy a supra
Cars like Gary's and mine are far to good to be broken, it's not all about the money when you have put so much of your life into a car!!
Hope you find a good home for it bud, it's a fine example of a modified "2"
Steve
danjama
Post by danjama »
Steve
Well said...
I personally hate to see mr2's broken.
SuperRedMR2
Post by SuperRedMR2 »
That is gorgeous mate, good luck.
Love the louvres on the rear.
TheBaker
Post by TheBaker »
Why the hell would you break such a great example? :shock: :roll:
Looks beautiful, GLWS! :thumleft:
archangel
Post by archangel »
Looks like something pretty special. Just curious but it still have the stock 440cc injectors?
Ethan21
Post by Ethan21 »
Ermmm for more money to fund a straight 6 twin turbo supra
gazrev1tubby
Thanks for the kind words guys :thumleft:
archangel wrote:Looks like something pretty special. Just curious but it still have the stock 440cc injectors?
No bud, rev3 management and fuelling. Used to have a big turbo, with 870cc delphi injectors, with a power fc, but I went back to stock rev3 management, and a new ct20b, as the power delivery is far better in my opinion.
It's superb to drive!.
Ethan, it's not just about the money mate, id rather keep it whole. I'm not desperate for the money either, id gladly keep it, but sadly I know that it won't get used, and to see it deteriorate would be worse
JayUK91
Post by JayUK91 »
Sooo tempting...
What kind of power is it putting out?
gazrev1tubby
JayUK91 wrote:Sooo tempting...
I haven't dynoed it bud, running this setup, but I can only assume a similar figure to a rev3 running 1.1 bar. All I can say, is that real world performance, there is nothing in it between mine, steves (steve_c) and marks (markandlyn).
To be honest, I don't drive it hard. I pretty much stay around the mid range which is enough for me.
Jonny Hizzle
Post by Jonny Hizzle »
DO
NOT
BREAK
IT!
gazrev1tubby
Jonny Hizzle wrote:DO
NOT
BREAK
IT!
I hear ya buddy. The thought has crossed my mind, the clip is worth £2.5 - £3k alone!
Jonny Hizzle
NOT
BREAK
IT!
Yeah shame they're worth more in parts than whole, think about breaking mine all the time but then think how much work i put into it.
Saying that may change my mind the next time it breaks :lol:
Glwts - Bump!
Steve-O 2007
Post by Steve-O 2007 »
thats nice!! free bump!!
Hot-Lemon
two
Post by Hot-Lemon »
The pictures don't do justice to this superb Two, it looks even better in the flesh (metal) :thumleft:
GLWS
