I'm on FK coilovers at the minute which will drop from 25
- 60mm if I wanted to.
I'm around 30 or 35mm drop at the moment and I wouldn't go any lower for the simple facts of
1.
You'll scrape
/ bottom out on literally everything
2.
The ride is very bumpy or crashy as it is although that's maybe the shoals more than springs
3.
The MR2 is meant to be a drivers car, if you lower it that far you're not going to be able to drive it properly in the slightest and that's before you get to issues with arches scrubbing wheels
/ tyres etc
