Before I start this is my own fault. Basically I had removed the passenger seat, upon putting it back in I stupidly fully tightened the front bolts before putting the rear ones in.
Upon attempting to put the rear one in it tightened to a point and then made a rather loud cracking noise. Currently the seat is mounted correctly using the other 3 bolts however the rear left one just spins freely within the hole and won't come out of the hole, nor will it tighten.
I'm guessing I've ruined the thread in the hole which is annoying, or could it just be that the thread on the bolt has gone and that is what is causing it to spin. I've got plenty of free time and don't generally carry passengers, is there any way I would be able to save the thread in the hole if it is still intact and be able to remove the bolt?
Loose passenger seat.
Re: Loose passenger seat.
Have u tried wedging the bolt away from the hole with a flat driver then try to undo it.. That might work to get it out
If you sit in it and do the funky chicken is it loose?
If so its an MOT fail
You have broken the captive nut off the chassis . The only way you will be able to fix it is to chisel off he cover piece of metal over the captive nut under the car , then grip the captive nut with some visegrips and undo the bolt .
You will then need to get the captive nut reattached ( welded ) if it is still useable ,probably cross threaded though .
If you go down the route of having to have a new nut welded under the chassis remember the bolts which hold down the seat are metric fine thread .
Once all that is done cover the captive nut with a suitable new piece of metal and underseal or paint as required
If you are wondering yes this has happened to me
3sgte wrote:You have broken the captive nut off the chassis . The only way you will be able to fix it is to chisel off he cover piece of metal over the captive nut under the car , then grip the captive nut with some visegrips and undo the bolt .
My reply was about to be "b0ll0cks" but then I remembered that the car is going in for some welding work so will get the garage to sort it (unless obviously the screwdriver trick works). I blame Toyota
