I think I may have found what was causing it.
I'm not sure what the part is called but the semi circular clamp thing that holds down the camshaft where it connects to the distributor.
One of the bolts holding it down turned out not to be fully tightened.
I dunno what torque they should be at but i did it up nice and tight and as it tightened i saw oil being squeezed out from under it.
I degreased it all and smeared a bit of sealant around its edges before refitting cam cover.
So far so good but won't know for sure for a while.
Also in hindsight I thought I probably shoulda found out if it has some sort of gasket itself and removed it, cleaned it properly and resealed it.
Anyway hopefully I have sorted it, can't be bothered removing the cam cover again!
Oh and btw I had already tried distributor o ring seal at the same time I replaced the cam cover gasket the first time.
