The only problem is that I can't find them from the usual sources
The existing ones might not even be salvageable because the threads at both ends of the track rod are seized
Next option is to use non-standard ones for another car.
Red Wedge wrote:Just been on what I think is their website(http://www.sbits.net/catalog/index.php
) and they don't have any AW11 parts listed.
I'm also looking for new track rods as well as other suspension bits.
PeteP wrote:I cannot find the rear outer joints
- what we call track rod ends
jimi wrote:If you look closely at the Twos R Ustie rods they use a different ball joint to Mr T, they use a female end
(same as a track rod end) not a male one
kaiowas wrote:jimi wrote:If you look closely at the Twos R Ustie rods they use a different ball joint to Mr T, they use a female end
I seem to recall seeing somewhere that they use a standard front track rod end.
elbon50 wrote:If that's all OK I would suggest using a Dremel cutting disc to slit the old turnbuckle along it's length& then force the split open to release the balljoint
