Alloys 17 x 8 ET 35
Tyres 215/45/17
1. The tyres are so close to the strut I think I need spacers
2. The tyres are catching on the arches (even so I cannot turn on full lock)
Has anyone else encountered this issue? Presumably 45 profile on the front is too large?
Is an 8J rim too wide? I thought lots of people ran these.
Tyres not fitting in wheel arches
Re: Tyres not fitting in wheel arches
You will be ok with that on the rear but I had the same spec on my 2 and ran slightly stretched 205s on the front. No problems with fitment at all.
I have had this on the front too.
You need either 215/40/17 or 205/45/17
Alex O wrote:I have had this on the front too.
I agree, you'll need to calculate the sidewall aspect ratiois to ensure you get it right.
The sidewall is a percentage of the width. e.g. 215/100*40=86 that means the sidewall will be 86mm.
On a 45 with the same width youll be 11mm bigger (which is 22mm rolling diameter larger) and therefore you will hit the suspension perch.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
