When I bought my car it had an apexi power fc,commander and boost solenoid fitted,the car had previously had water meth installed and there are dyno printouts to around the 335bhp mark,not sure if this is at the wheels or or flywheel.
Mods now are as follows,apexi filter,berk downpipe,blitz nurspec,greedy intercooler and spal fan.
Running 1.25 bar of boost on current setting also has a higher setting of 1.2bar.
I have changed the dizzy and rotor arm,plugs seem fine but coil needs swapping I think,there's a clicking noise from it which causes a dip in revs on idle.
My issue is overdueling and a recent lack of power, would I be best removing the power FC and running a standard ecu with ebc? That would free up some cash for other goodies.
I can't ever see myself running huge power so unsure if I'll ever see a benefit from the apexi,it is good for keeping an eye on things though.
