[Mk2] [Generic] 6.5" speaker spacer ring options
smig
Post by smig »
My standard front speakers are well and truly goosed.
I've got a pair of 6.5" Infinity's ready to install but I need some spacer rings.
I haven't got any MDF to make my own, but have seen ebay links to other car manufactures rings which look like they'd do the job.
Has anyone used ant of the following:-
http://www.ebay.co.uk/itm/181153277269? ... 1423.l2649
http://www.ebay.co.uk/itm/151012053132? ... 1423.l2649
http://www.ebay.co.uk/itm/330874516516? ... 1423.l2649
Or, has anyone got any better alternatives?
smig
Re: [Mk2] [Generic] 6.5" speaker spacer ring options
Post by smig »
Anyone?
ChrisW
Post by ChrisW »
Have you sorted this yet? I needed 24mm thick spacers when I fitted my 6.5" Infinty speakers but I can't remember where I got them from.
smig
Post by smig »
Yeah, I'm having a bit of building work done at home, and there was some 20mm MDF lying about, so I made some spacers.
Job done (but not as smart as yours)
mrfil13
Post by mrfil13 »
I got 18mm spacers from here http://woodshapes.co.uk/
I have infinity 6530cs speakers and they fitted fine, just need to cut some of the out ring once fitted so that the door went back together, also had to cut away the ring inside the door cover but might have been able to get away with that if i had started by cutting away at the ring.
Return to “ICE and Security”
