Should power steering pump run constantly when ignition is on?
toecutter
Post by toecutter »
Rev 2 turbo
As title, should the power steering pump run constantly when ignition is switched to on (engine off)?
philmr2
Re: Should power steering pump run constantly when ignition is on?
Post by philmr2 »
Yes will go off after about 40 seconds :thumleft:
toecutter
Post by toecutter »
Mine was doing it, I removed one of the leads from the pump relay to stop it firing up whilst I traced a fault, put lead back on, now its not coming on.
Any ideas what it could be?
toecutter
Post by toecutter »
Turned out to be the relay, seemed to switch OK but tried a spare on it and pump came on.
RST
Post by RST »
PS relay is known for sticking on SW20's. Quite often off, but yours might have stuck on. I've had it before but clicking off-on-off-on cleared it, if not a new second hand one might be worth a shot.
