Building a wiring loom.. Where do i get wire from?
RyanRs
Post by RyanRs »
I am rebuilding part of the body harness to re-position the ecu behind the passenger seat as the boot now being a Bmic is no longer sealed from the elements and the ecu could get wet.
The only issue i seem to be having is finding somewhere that sells about 25 different colours of automotive cable!? Off the top of my head i need 25 x 3m lengths of thinwall PVC. I can companies that sell 11~12 colours but nowhere that goes into striped colours etc? I know there is ways around this ie labelling the ends but from past experience, theres too much risk of labels coming off / mistakes being made when trying to feed wires down through tight locations etc.
Anyone got any ideas?
MR2 Rich
Re: Building a wiring loom.. Where do i get wire from?
Post by MR2 Rich »
Could paint the cable yourself if you can't find anywhere?
No 2 :(
LimeyMk1
Post by LimeyMk1 »
http://www.vehicle-wiring-products.eu/V ... mepage.php
or
http://www.polevolt.co.uk/
I got my loom wire from the first one but have used both and can recommend either one. :thumleft: Biiiiig selection of 32 strand 0.20mm2 wire. :thumleft:
ej2_sir
Post by ej2_sir »
Scrapyard? find a big estate and strip the loom, guarantee you'll have more colours and wire than you will ever need
