High pitch whirling noise from engine bay
Hiya. i have an f reg mk1b and since saturday afternoon a high pitch whirling noise has started coming from the engine bay. at first it sounds like it is coming from the tvis area but after closer inspection it could be coming from the alternator area!!! belts look ok but im no expert!! The high pitch noise gets faster when accelarating even if not moving so assume its not gearbox. any ideas would be much appreciated. thanks
- Lauren
- IMOC Committee
Re: High pitch whirling noise from engine bay
Bearing on the way out on a pulley or idler?
2020 GR Yaris - Circuit Pack
ooohh. could be. thanks mate. ill check it out. sounds like it could be a fun job
Remove the alternator belt and start the car. Will help narrow it down as if the noise goes its either the alternator bearing, water pump or the bottom pulley delaminated.
thanks for the help guys. i sprayed the alternator and belts with wd40 last night. left it to soak over night and after starting the car this morning the noise vanished after 10 seconds. so know that was the problem area. will wait for noise to come back before replacing alternator and belt
Sometimes i noticed when i did some work on mine a few weeks ago that my alternator and belt were not 100% square, this cause a squeak only on start-up. I have re straightened and then greased everything up and no more squeal now.
Alex
Alex
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming 'stop raping me'
I really hope you didn't spray the alternator belt with WD40! WD40 is a lubricant, the belt is supposed to grip not slip
no sorry i meant i sprayed the alternator with wd40. i used silicone spray on the belts!!!
