I pulled over and discovered that the car was low on water and then when round the front discovered why, a stone has hit the rad and pierced a small hole
Having topped up the water level I drove a few miles back to my folks place and noticed that the temp needle shot up
So, my questions are:
1) What would make the water temp needle give such erratic readings? Air in the system?
2) Is it worth seeing if radweld will fill the small hole in the radiator
Any thoughts
