[Mk2] [Generic] Removing the twin cam turbo strip ??
andy585
Post by andy585 »
I have new twin cam 16 turbo decals and was wanting to remove the plastic strip and then add the decals how do I do this
I have noticed one screw inside the edge of the wheel arch any others?? also I this easy to remove without damage
simpson_eh
Re: [Mk2] [Generic] Removing the twin cam turbo strip ??
Post by simpson_eh »
yes think there are 2 nuts on the inside, you have to get into the space where the seat belt goes, have a feel around pretty sure its two im sure someone will correct me if im wrong
tony
toxo
Post by toxo »
You're right(ish). One 10mm nut inside and one in the wheel arch (in addition to the screw). You'll need a deep 10mm socket to get the one inside off, the threaded bar it's on is really long.
Steve-O 2007
Post by Steve-O 2007 »
the one in the wheel arch will have a high chance of snapping as well :cry:
