Can someone give me some help to identify the camshafts in a 3s-gte rev 3 turbo. I am not sure that they are standard. Also clearances.
I might need a good second hand set if anyone can help.
Thanks,
Chris
[Mk2] [Turbo] Turbo camshafts
Re: [Mk2] [Turbo] Turbo camshafts
ive got a decent set of rev3 turbo cams if you do need them.
pm if required
i can also supply rev2 turbo ones if they happen to be different
pm if required
chrishewett wrote:Can someone give me some help to identify the camshafts in a 3s-gte rev 3 turbo. I am not sure that they are standard. Also clearances.
Thanks,
Chris
What makes you think they are not starndard?
Without going in to details. The numbers on both cams are 88362. Cant see any other marks.
0.15 > 0.25mm in the intake
0.20 > 0.30mm on the exhaust
JJ wrote:0.15 > 0.25mm in the intake
0.28 - 0.38mm on the exhaust for Rev3 on.
chrishewett wrote:Without going in to details. The numbers on both cams are 88362. Cant see any other marks.
That is just a casting number and is on Rev2 and Rev 3 cams I have here.
Thanks for all the replies. A real help.
I have just bought a good second hand complete head. I will play about with the old one at my leisure.
I'm off to Spa now for a classic car race meeting. Will finish the mr2 when I get back!
Chris
Chris
