Currently having my wheels (teardrops) refurbished the original nuts are a bit tatty and rusty and think will probably let the wheels down a bit. Are new wheel nuts available anywhere are there also any other options for standard alloys as always felt the original nuts stick out a bit far
Tom
Wheel nuts
Wheel nuts
Re: Wheel nuts
If they're not available you could always get the old ones re chromed.
Re: Wheel nuts
tomsky wrote:Currently having my wheels (teardrops) refurbished the original nuts are a bit tatty and rusty and think will probably let the wheels down a bit. Are new wheel nuts available anywhere are there also any other options for standard alloys as always felt the original nuts stick out a bit far
Tom
You could get some roadster nuts, they're shorter Tom
Are you sure yours are rusty or just mucky
Try soaking some in vinegar overnight
Re: Wheel nuts
I've tried the vinegar idea and it's a waste of time.
Still leaves nasty rusty patches and grime and stinks.
Re: Wheel nuts
SuperRedMR2 wrote:I've tried the vinegar idea and it's a waste of time.
Did you try white vinegar Alex ?
Or cocacola ?
Doubtful if they'll shift rust though
Re: Wheel nuts
Yeah white vinegar is what I used.
You can pick up a set of roadster wheel nuts for about £25 with lock nuts too.
I might be changing mine but not for a while. Am undecided on what colour to go for.
Re: Wheel nuts
I'm using Mk1 nuts with roadster wheels at the mo
They do the job but are too long
Have seen a roadster set on the Bay
Re: Wheel nuts
just to confirm do the roadster nuts fit the original teardrop alloys and hub then and with the only difference being that they are shorter?
Tom
Tom
Re: Wheel nuts
tomsky wrote:just to confirm do the roadster nuts fit the original teardrop alloys and hub then and with the only difference being that they are shorter?
Tom
Mk1 teardrop nuts fit roadster wheels
So the answer to your question must be yes Tom
Re: Wheel nuts
Here in Germany these nuts are available very cheap as aftermarket parts so it makes no sense to reburbish used ones:
http://www.ebay.de/itm/1-Febi-Bilstein- ... 231a5278c8
Re: Wheel nuts
Have had a Mk1b wheelnut soaking in white vinegar for 4 days
There was no rust on it but quite a lot of hardened black stuff
Bits of black have been falling into the vinegar
When I removed the nut from the vinegar & wiped it today all the remaining black came off & the nut is sparkling
Have put some more nuts in the vinegar now
