3sgte bolts
mk1bexwa
3sgte bolts
Post by mk1bexwa »
Hi All,
Need some help.
I am currently in the middle of my mk1.5 build and have run into a bit of a problem. I have some bolts missing, that we can see.
Bolts needed:
Gearbox bolts
Flywheel bolts
Starter motor bolts
Does anyone know the sizes for these bolts? Or even where to get them?
Thanks in advance
Beckie
dawesy
Re: 3sgte bolts
Post by dawesy »
ill have a gander and see if i have some in my bolt store :)
do you need all the gearbox bolts?
and is it flywheel to crank or coverplate to flywheel?
mk1bexwa
Re: 3sgte bolts
Post by mk1bexwa »
Think I need both
toxo
Re: 3sgte bolts
Post by toxo »
If you don't know the sizes or pitches and no one on here can help you can get them from Toyota... you will think they were made of gold though!
