I have my engine out but cant see how to remove the pump from it
Any help please?
[Mk2] [NA] removing fule pump
Re: [Mk2] [NA] removing fule pump
racingrepairs wrote:I have my engine out but cant see how to remove the pump from it
Any help please?
If I am correct you need to drop the fuel tank to get to it, as its under the tank
The fuel pump?
Drop the fuel tank and unbolt the plate that holds it in...it is in the tank
Ok, the tank looks well tucked in there!
Any idea how to remove?
Breaking rev1 turbo http://www.imoc.co.uk/forums/viewtopic. ... 88#1496388
Also see http://www.imoc.co.uk/forums/viewtopic.php?t=170899
racingrepairs wrote:Ok, the tank looks well tucked in there!
Here is an exact "how to" for fuel pump and fuel tank removal
http://www.lovehorsepower.com/MR2_Docs/ ... emoval.htm
PS you shouldn't go far wrong with that write up ^
It is one of the more decent ones that I have stumbled across in my travels and comes with handy step-by-step photos
Thank you so much
racingrepairs wrote:Thank you so much
No probs
Remove under trays front to back
Remove the metal coolant lines
Remove cross braces under the tank
Remove one handbrake cable to allow it to be moved to one side
Undo pipes attached at firewall to fill neck breathers etc
Remove centre console
Remove ash tray
Remove plate with wiring going through
Remove tank straps underneath and prise tank out whilst someone guides wiring out safely
That's the gist of it, most things will become obvious once you start
I'm about to do it on mine again, this time on a gravel drive rather than the nice paved one I did it on previously
Remove ash tray
Damn you Karl, do it the easy way!
Fozzy wrote:Damn you Karl, do it the easy way!
Any suggestions on which pump to replace with. I know if I use my old tubby one that sods law dictates it will fail
racingrepairs wrote:Any suggestions on which pump to replace with. I know if I use my old tubby one that sods law dictates it will fail
Have you seen there is an upgraded one for sale on here atm? - its what I would suggest
I will dig out the link for you...
Wouldn't new be best?
racingrepairs wrote:Wouldn't new be best?
It would yes
I fitted a rogue Motorsport pump in mine, although I can't review it too well, as mine has done very few miles. I trust rogue to use a half decent product, so I didn't mind giving it a go, if your unsure go with the name therefore Walbro
Looking to pay how much
Rogue pump is just over 60 quid, walbros seem to be 70-90 quid new
