BoV not working
BoV not working
Rev 2 Turbo 205 charger cooler setup. HKS ssq BoV, dug out the BoV from under my AFM and noticed the little tubing that goes to the inlet manifold has split, seems springy still inside the BoV. Is it not working due to that split tube?
- IMOC Moderator
Re: BoV not working
not too sure which pipe you mean, why is the BOV under the AFM??
you got any pics??
you got any pics??
Re: BoV not working
Yea got pics but working from iPhone at the moment, will load up picture 2night but by then I'll have replaced the hose at work, so hope that fixes it.
- IMOC Moderator
Re: BoV not working
if you mean the vac hose on the bov, then it would cease to function if this was split, it sounds to me like you're talking about a recirc pipe, in which case the valve should still work, although would probably run like crap
Re: BoV not working
WD40 the BoV diaphragm at work, and fitted a new small pipe from the BoV to the inlet chamber, works now.
