[Mk2] [NA] Calling all V6 owners, exhaust help required.
blue2
Post by blue2 »
Hi,
Im currently in the process of replacing my exhaust. I need to know what pipes are needed for the 3.0 engine. Basically everything except the backbox. Im not sure whether original MR2 ones will fit or whether I will need the ones for the actual Camry engine. Any help with this would be great!
Thanks :D
p5ycho
Re: [Mk2] [NA] Calling all V6 owners, exhaust help required.
Post by p5ycho »
you need the original v6 manifolds and downpipes,
the downpipe gets modded and extended to mate with your choice of exhaust.,.
if the engine u are using is a 3vzfe then this downpipe...
the straight end is the side that gets modded/extended to mate with your backbox
PW@Woodsport
Post by PW@Woodsport »
Hi Dan, your downpipe/centre pipe section is bespoke to your car, you need to start with a new 3vz-fe downpipe set and modify it to fit your rear silencer, if you need anything else just ask, thanks paul.
blue2
Post by blue2 »
Thanks guys thats great. Paul when you did mine I had the Y-pipe modification, I take it that will be coming off with the old pipe? Is much modification required to get it to fit? Thanks again!
PW@Woodsport
Hi, yes if you are renewing the downpipe section the modified Y is part of that, so you will just be using the standard Camry downpipes but then modified to fit your rear silencer.
blue2
Post by blue2 »
Thanks Paul, ill let the garage know tomo and get the parts ordered! :D
blue2
Post by blue2 »
Hi Paul just found this
http://www.ebay.co.uk/itm/TOYOTA-CAMRY- ... 5aeebd9d68
Im getting my local garage to fit it, will it be a fairly straight forward job or require loads of modding?
