How the hell is this going to come out?
SuperRedMR2
Post by SuperRedMR2 »
How the hell am I going to remove this bolt?
I've beaten the bracket down to allow more grip with the Mole Grips, but they just destroy the bolt :(
I was going to buy a set of rounded bolt removal sockets, but anyone got any more ideas?
It's the rear ARB bracket by the way.
Help!
stenky
Re: How the hell is this going to come out?
Post by stenky »
nut extractor first (i personally have them and they are marvelous, where space permits) and then the good ol' electric drill
SuperRedMR2
It's not really nut shaped anymore, the material is falling apart if any pressure goes on it.
I don't want to be in a situation where I have to drill out an m10 bolt.
kherseth
Post by kherseth »
if there is no heat sensitive parts close to it you could try heating it red hot, then while still warm use your mole grips to force it loose. It worked wonders on my Opel Omega exhaust.
SuperRedMR2
Yeah I was considering heating it red hot, then cooling it down quick and loosening it that way.
scomr2
Post by scomr2 »
Grind two new flats to give the mole grips or adjustable spanner a better chance of gripping.
Once it starts to move spray some lubricant in and alternate tighten / loosen to break up the rust.
Good luck!
stenky
Post by stenky »
SuperRedMR2 wrote:Yeah I was considering heating it red hot, then cooling it down quick and loosening it that way.
this is what will make the steel brittle and it WILL snap if you happen to grip it and turn it
pistol pete
Post by pistol pete »
shortly followed by lots of swearing as you have cracked your knuckles across something :oops:
stenky
Post by stenky »
when it comes down to heating, i would rather heat (not red hot) the surrounding material to achieve thermal expansion, which could relieve the tension in the thread.
and don't forget that bolt's flat head surface is easier to drill than after it snaps (actually it's impossible to hit the centre of the bolt after it snaps) i have tried it several times, always misaligned...
i personally managed to grip even the roundest bolt heads/nuts with the extractor set. as the helix in them is slightly conical and the helix edges fairly sharp, it will catch even on perfectly round bolt :)
kaiowas
Post by kaiowas »
How solid is the bracket? I'd be tempted to bend it down away from the chassis rail slightly then use a large universal adjuster to try and turn the bracket in the hope that the bolt goes with it
jimi
Post by jimi »
kaiowas wrote:How solid is the bracket? I'd be tempted to bend it down away from the chassis rail slightly then use a large universal adjuster to try and turn the bracket in the hope that the bolt goes with it
Worth a try, give it a good few hours soak with Plus gas, then try the above.
If the above doesn't work then I think you are already there !
the "cut it off flush, centre punch and drill it out, starting small and working up" method may be your only option.
SuperRedMR2
There is a grommet next to the bolt, so i'm going to whip that off and spray penetrating oil all around the area in a hope that it soaks in.
I will end up buying the reversed sockets in a hope to get it out. Heat will be the final option.
I was tempted to hack saw the bracket off in an attempt to get some extra leverage on it.
jimi
Post by jimi »
SuperRedMR2 wrote:There is a grommet next to the bolt, so i'm going to whip that off and spray penetrating oil all around the area in a hope that it soaks in.
I'd recommend Plus Gas :thumleft:
elbon50
Post by elbon50 »
I have a very similar problem with one of the exhaust hanger bracket bolts Alex
Have removed the exhaust to get access
MartG
Post by MartG »
SuperRedMR2 wrote: Mole Grips,
In that sort of situation a Stilsons wrench is much better than Mole Grips, as the harder you pull on them the tighter they grip
SuperRedMR2
Lack of room and the bracket being in the way is the problem for Stilsons, Mart.
elbon50
Post by elbon50 »
Have got my bolt out Alex :)
I have a set of these
http://www.ebay.co.uk/itm/IRWIN-5PC-BOL ... 1c2e83e3d4
Worked a treat :thumleft:
Paul Cyclops
Post by Paul Cyclops »
elbon50 wrote:Have got my bolt out Alex :)
I've got that particular set and they'll work on nuts that are practically cylindrical with a modest-sized breaker-bar. Not particularly cheap but an excellent product.
I bought them when I discovered that a previous 'technician' had ludicrously over-tightened the sump-plug on my Saab Turbo, a car I felt obliged to change the oil in every 3k.
michaeljapp
Post by michaeljapp »
Do you have enough room to tac another head onto the bolt?
The heat from the welding breaks the rust seal in most cases.
Toymad
Post by Toymad »
Another vote for those Irwin extractors, they can grip on some amazingly rounded bolt heads.
