You may need to remove the pistons from the calipers, clean them
& clean out the grooves where the seal
& rubber boot sit in the cylinders Ian
You'll most probably need to buy a new kit of seals
& rubber boots to reassemble them
I'm in the process of a similar job at the mo
Rust forms in the top groove, behind the edge of the boot and makes the pistons stiffen up
It can be a biggish job, perhaps you could refit your original single pot calipers while you do the ST185s
Presumably they are twinpot 185s
I can take you step by step through how I did mine
Peter
