Im currently running the normal black billies,stock springs and have 17 inch wheels.
My question is which suspension would give me a drop without been a hard ride.
HighwayStar wrote:Struts are either yellows or stock unless TCB can still get new blacks.
Nic wrote:HighwayStar wrote:Struts are either yellows or stock unless TCB can still get new blacks.
Toyota still supply the OEM black Bilstein/Toyota dampers, I recently sourced a new set for around£50 each.
HughesR1 wrote:I actually found my Tein Superstreets with the dampers set quite soft to be OK on 17" wheels, but I really think it depends on what your personal view of hard/soft suspension is.
HughesR1 wrote:If I had the money spare I'd go new yellow Bilsteins and Eibach springs, can't go wrong![]()
Harold wrote:If they were£50 each then they certainly weren't bilstein,
£150 perhaps.
Nic wrote:Harold wrote:If they were£50 each then they certainly weren't bilstein,
£150 perhaps.
Definitely black Bilsteins but yes they were a bit more than I remembered, roughly£86 each including VAT and postage.
Harold wrote:Unless used I've no idea how you got them so cheap, from tcb they're a smidge under£150 each before VAT.
It's actually cheaper to buy yellows from camskill.
