Anyone notice anything intresting when stripping down a redtop beams engine?
just stripped head off and dismantled it and was suprised at something
beams mr2
Re: beams mr2
Port angles? Or something more exciting?
Re: beams mr2
The intake port angle is brilliant, but i knew that before i took off the camcover.
Re: beams mr2
what i found that surprised me was the head casting. it had all the fittings for vvti on exhaust side (except needs some machining/holes drilled etc and xtra sensors)
so it appears there is a possibility to run dual vvti with the redtop head
