stuMR2eye wrote:Here's the guide I followed:
http://stephenmason.com/cars/mr2foglight.html
Need to be very careful with drilling though and has to be central on the screws to work.
JohnnyC wrote:With a drill![]()
There's two philips head screws per light.
Good luck![]()
raptor95GTS wrote:take the front bumper off first, it does come off with a bit of wiggling, and that'll make it easier to get in with the drill bit![]()
edit: I assume you are talking about the front fogs as the back ones are much easier!
asdrewq wrote:raptor95GTS wrote:take the front bumper off first, it does come off with a bit of wiggling, and that'll make it easier to get in with the drill bit![]()
There are 2 plastic push-fit lugs which attach the bumper to the crash bar above/behind each fog light, so don't try this unless they are already missing or you want to mangle your bumper.
I got a long 6mm drillbit fron ebay and retapped mine for M6 allen head bolts.Use lots of drilling lube and watch for heat buildup
- you can end up melting the plastic tabs on the fogs.
asdrewq wrote:I got a long 6mm drillbit fron ebay and retapped mine for M6 allen head bolts.
