i've checked for play in the hub and ball joint and both appear fine.
the noise is apparent when i'm lifting the hub up and down.
Help please, its driving me mad!!!!
![Pray :pray:](./images/smilies/eusa_pray.gif)
andrew30044047 wrote:After taking off the wheel& manually lifting the hub I'm inclined to thinking it may be the insert.
The noise is defiantly most noticeable around the centre of the shock.
It's a bit of pain as I just got 2 new TRD top mounts that were a bit expensive& may need to buy a new insert.
pacman wrote:I've had this exact problem recently.Replaced the drop links but that didn't cure it.
After a little more research it turns out that the 19mm nut which mounts the strut to the topmount
(under the black cover) had come loose by maybe 2/3s of a turn
(fairly common, apparently).
Tightened that up and the knocking disappeared.
