Hi Grant,
It all depends what you're after, and what your budget is.
If you're after sound quality
(SQ), then a good set of 6.5" components
(6.5 inch bit goes in the doors, tweeters go in the little triangle bits) and a 10" subwoofer driven by either a pair of 2 channel amps
(bridge the second for the sub), or a 4 channel amp
(again, bridge 3+4 for the sub) will do the job nicely.
If standing outside your car with enormous ear bleeding amounts of bass is your thing
(Sound pressure level
- SPL)
(why!!!
) then you'd be better with a couple of 12" subs and big amps to drive them.
Your box needs to be the right size for your sub, the manufacturer will give a recommended sealed or ported enclosure size and you need to get that volume to get the correct response from the system.
A worthwhile investment is soundproofing.
a bit of a PITA to do, but cuts out that road/engine/exhaust noise
(if you want to hear your exhaust, open the window
I've gone for a SQ system, with a Becker Mexico Pro head unit, Becker CD changer, DLS A5 3 channel amp, Focal Utopia 165 components and an Aliante 10si sub.
Not fitted it yet!!
This forum is very useful:
http://www.talkaudio.co.uk/
Cheers,
Jon
