[Mk2] [Turbo] Best discs for track car (using cw pads)
As above, re vaing the brakes and want to know what the best discs to get... Are cheap ones viable or should i go for more expensive ones...?[/quote]
Re: [Mk2] [Turbo] Best discs for track car (using cw pads)
with the right pads, the standard discs will be all most people ever need
just make sure the rest is up to scratch - calipers operating correctly, braided hoses, decent fluid and bobs your uncle
Quigonjay wrote:with the right pads, the standard discs will be all most people ever need
Cheers mate,
Just sorting the calipers now as every corner had sticky sliders, bought some rbf600 brake fluid and about to get some btraided hoses so all good, thanks.
Hi Add, recently overhauled all my calipers, fitted new OEM discs, pads and Motul RBF600 fluid, I've not tracked the car since but very pleased with the results. I also fitted braided lines and master cylinder brace at the same time which has really helped firm up the pedal feel.
Nic wrote:Hi Add, recently overhauled all my calipers, fitted new OEM discs, pads and Motul RBF600 fluid, I've not tracked the car since but very pleased with the results. I also fitted braided lines and master cylinder brace at the same time which has really helped firm up the pedal feel.
Cheers Nic
Got some chris wilson pads which should work pretty well. Will get some oem discs for it then
A branded disc is as good as any other branded disc for normal use.
