Does anyone know what this vacuum hose is suposed to connect to? It starts just above the idle adjustment screw but there doesn't seem to be anything to connect it to.
Can't get a steady idle and think this is the culprit.
Stray 4AGZE vacuum hose
Re: Stray 4AGZE vacuum hose
Hope these pics help - seems to go to somewhere on the fuel rail
Did some research last night and it seems this vacuum hose connects to the charcoil cannister. Some sort of filter for fuel fumes.
It connects to a metal pipe near the fuel rail (that I forgot to fit), bends around the block to the ECU water temp sensors and continues from there to the charcoil cannister next to the fuel filter..
European cars weren't fitted with one so I just blocked it of.
