Hi
just wondering if there are fan jet washers available for the mk1
thanks kev
fan jet washers
Re: fan jet washers
We have started using the Volvo S40 & S60 ones in the MK2, not sure if they would be any good in the MK1
http://www.imoc.co.uk/forums/viewtopic.php?t=168626
Re: fan jet washers
I needed a new washer jet late last year for my Mk1 and had looked at Mk2 ones, but they're quite a bit bigger. If you definitely wanted to do it you would have to increase the size of the holes in the bonnet and also possibly cut a hole through the webbing underneath the bonnet below the washer jet holes for the pipe to connect on to and to give easier access.
Also, using toyodiy.com it suggests that the Mk1 washer jets are unique to the Mk1.
Keep us updated with your findings.
HTH.
Cheers,
Tom
HTH.
Cheers,
Tom
Re: fan jet washers
When I get my Volvo ones delivered I'm more happy to take some measurements for people if that would help?
I have no clue if they are bigger or smaller than the standard mk2 ones tbh
Re: fan jet washers
Hi
it has been suggested that yaris ones might be the way forward next time one comes in work will have a gander
kev
kev
Re: fan jet washers
kevs aw11 wrote:Hi
kev
You might be interested in reading this...
http://www.imoc.co.uk/forums/viewtopic. ... t&start=40
The yaris ones are weaker, give poor flow and are substantially bigger than the standard mk2 ones sitting proud on the bonnet. Just food for thought
Re: fan jet washers
Hi karl
what about the paseo I am sure they had a similar bonnet need to do more research
kev
kev
Re: fan jet washers
I have moved the washer jets to the wiper arm using washer jets from a Mercedes Sprinter rear wiper arm.
Re: fan jet washers
XLarge wrote:I have moved the washer jets to the wiper arm using washer jets from a Mercedes Sprinter rear wiper arm.
Very interesting idea Eric
Re: fan jet washers
Have you got any pictures - I've looked at doing this before...
I'd be intrigued to see it - aren't the wiper arms from the Sprinter a little bulky?
Re: fan jet washers
KarlBristol wrote:Have you got any pictures - I've looked at doing this before...
I may be wrong but think Eric has found a way of attaching Sprinter nozzles to the MR2 arms
Can't find any relevant pics at the mo
Re: fan jet washers
Yes, I mounted only the nozzels from the Sprinter to the original MR2 wiperarms. It was a bit tricky to route the water hoses out of sight but the result is very decent. Will take some pictures when I come to my shed again next week.
Re: fan jet washers
I look forward to the pictures
This is the only other thing I've ever seen that seems to come close:
http://www.ebay.co.uk/itm/FLAT-WIPER-BL ... 2ec6bb4bca
I have found universal connector for jets to arms but I'm not sure what it would look like/spray like
http://www.ebay.co.uk/itm/1x-Triple-Was ... 51a7bb977b
Re: fan jet washers
My mate on his E30 used one big wiper blade and moved the motor to the centre of the windscreen, and then used a bus type method with hose going up the arm and sprays along the blade.
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming 'stop raping me'
Re: fan jet washers
Googled for pictures of the washer nozzels I´ve used and found a picture of them:
http://i.ebayimg.com/t/SCHEIBENWASCHANL ... Sr3BQJPCmU)c!~~60_12.JPG
*edit: Can´t get the link work. You´ll may try this one:
http://www.ebay.de/itm/ws/eBayISAPI.dll ... rid=229487
Re: fan jet washers
Moved my MR2 out of his shed it was parked the last 10 years, gave it a good wash and didn´t forgot the pictures of my washer nozzels modification I´ve promised.
As told, very decent and difficult to notice:
Re: fan jet washers
XLarge wrote:Moved my MR2 out of his shed it was parked the last 10 years, gave it a good wash and didn´t forgot the pictures of my washer nozzels modification I´ve promised.
Image Replaced With URL For Quote http://www.toyotacarina.de/mr2_rebirth_28.jpg
Image Replaced With URL For Quote http://www.toyotacarina.de/mr2_rebirth_29.jpg
Looks a neat fitment Eric
How did you feed the pipes through into the boot (trunk) ?
Re: fan jet washers
Will take a picture of that (with the trunk open) . Forgot the details as ten years gone in the meantime. But I´ve used existing holes and didn´t drill a additional one to the shell.
Re: fan jet washers
These seem to be similar nozzles to the ones you used Eric ?
Peter
Peter
Re: fan jet washers
Seem to be a bit similar to the one I´ve used. The Merc parts I´ve choosed have four outlets, one on each corner.
