Castrol Edge - Buy 4L & get 1L FREE
oilman
IMOC Affiliated Company
Post by oilman »
Buy a 4 litre bottle from Castrol's top of the range Castrol EDGE range for only £39.99 and receive a 1 litre FREE!
Fancy stocking up? You can order any number of 4 litre bottles to get the same number of 1 litre bottles FREE.
Our Castrol Edge offer is available in 0w-30, 0w-30 A5/B5, 0w-40 A3/B4, 5w-30, 5w-40 & TD 5w-40 grades, all of which can be found HERE > > > >
*Does not apply to Castrol EDGE 10w-60*
That's not the only offer we have running :
- Millers CFS engine oils only £43.99
- Millers NANODRIVE engine oils - Buy 5L and get 1L FREE
- 15% OFF all Mobil car engine oils - code: MOBIL15
- 20% OFF all Winter products
View all current offers from Opie Oils HERE > > > > >
...and we now accept PayPal.
As always, if you have any questions or need any advice then feel free to ask
- The team at Opie Oils
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
MR2 Rich
Re: Castrol Edge - Buy 4L & get 1L FREE
Post by MR2 Rich »
Hi Oilman.
I've used the Fuch Titan 5w40 for my MR2 NA 1992 is this the best to use (other than the ester based oils)?
I've also got a 2005 1.3cdti Vauxhall van, what would you recommend for this? I totally ignore the servicing intervals of 20000 miles and do it every 6000 miles because there's a known issue with the service intervals and the oil filters. If I do a search on your site for Vauxhall Corsa 1.3cdti it brings up very different results to any Fiat 1.3's? Due to it being the same engine what oil would you recommend? I've been using magnatec but don't really thinks it that's good?
Thanks Rich
No 2 :(
MR2 Rich
Post by MR2 Rich »
Forgot to mention my MR2's got 140k miles and my vans got 90k and neither use any oil :thumleft:
No 2 :(
oilman
Post by oilman »
Hi Rich
Which Titan 5w-40? There are a few.
The site sticks to the standard manufacturer specs, so it would list oils by the GM spec (LL-B-025) for the Corsa, but you don't really need them if you are changing at 6k. A 5w-40, like the Fuchs Supersyn or Gulf Formula G will be fine for that kind of use.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Tim
phone: 01209 202944
MR2 Rich
Post by MR2 Rich »
It's the Supersyn like the one you've recommended for the corsa. Why would you go for 5w40 over 5w30 for the 1.3cdti? Thanks Rich
No 2 :(
oilman
Post by oilman »
Hi Rich
Either really, but I'd probably go for this as it's a better oil and pretty much the same price.
http://www.opieoils.co.uk/p-69365-fuchs ... 5w-30.aspx
Supersyn 5w-40 is a decent choice for the MR2, but there are better oils without going for an ester one. The Fuchs GT1, Castrol Edge and Amsoil are a step up from the Supersyn without being ester based.
Tim
phone: 01209 202944
Return to “Opie Oils”
