Sorry I can not copy and paste the pdf but this is what it says in the cooling system descriptions
Radiator cap
The radiator cap is a pressure type cap which seals the radiator, resulting in pressurization of the radiator as the coolant expands, The pressurization prevents the coolant from boiling even when the coolant temperature exceeds 100C.
A relief valve
(pressurization valve) and a vaccum valve
(negative pressure valve) are built into the radiator cap.
The relief valve opens and lets steam escape through the overflow pipe when the pressure generated inside the cooling system exceeds the limit.
The vaccum valve opens to alleviate the vaccum which develops in the coolant system after the engine is stopped and the coolant temperature drops.
The valves opening allows the coolant in the reservoir tank to return to the cooling system.
Reservoir Tank
The reservoir tank is used to catch coolant which overflows the cooling system as a result of volumetric expansion when the coolant is heated.
The coolant in the reservoir tank returns to the radiator when the coolant temperature drops, thus keeping the radiator full at all times and avoiding needless coolant loss.
Check the reservoir tank level to learn if the coolant needs to be replenished.
I hope the above answers your questions.
