I'm not sure if anyone on here can help but there are a lot of Link ECUs around so I'll give it a go.
Does anyone know if the Link ECU software works on windows 8?
I've got a G3 so am using the slightly older version of PCLink, not the latest one for G4 only...
Wingers
[All] [Generic] Link ECU - Windows 8
Re: [All] [Generic] Link ECU - Windows 8
Yep I posted on there on Tuesday but haven't had a reply yet. I thought I'd try on here too just in case anyone knew.
Wingers
Wingers
I tried calling the UK dealer but they couldn't help. Have now sent an email too so will hopefully get a response there.
Wingers
Wingers
Because Link UK (i.e Thor) are no help whatsoever when it comes to the G3 and the forum is slow, hence he tried on this forum where there are a lot of Link ECU users, to get an answer.
92 MR2 Turbo Rev2 stock engine, Link G3 TURBONOZ mapped, T78: 487bhp & 364lbft; 11.78@120. NOW BREAKING: www.imoc.co.uk/forums/viewtopic.php?p=1542658
94 GTiR: 12.08@115 TOTB Sold
92 300ZX: 12.6@113 (415bhp) 570bhp, 500lbft
00 Clio 172
05 WRX PPP
00 Clio 172
05 WRX PPP
Windows 8, like Windows 7 before it has a compatibility mode so there is no reason to suggest it wont work. Both alos support virtualisation of older opperating systems.
Currently there is no solution for windows 8 available.
We do have it working in house and are currently in the final stages of testing.
I would expect a release in a few weeks.
This will be for the G4 range. However the USB drivers will be able to be used with the old G3 software you will likely have to do a double install of G4 software first and then the G3 software.
Looks like the bods at Link have got back to him
00 Clio 172
05 WRX PPP
00 Clio 172
05 WRX PPP
They have indeed.
For anyone who's interested, the official response was that there should be a G4 compatible solution in a few weeks, but there are no plans to do anything specifically for the G3. Having said that the G3 should work with the G4 drivers...
Prior to that I did get as far as wandering into John Lewis and installing PCLink on one of their windows 8 display models
That seemed to work fine, but I decided against walking in with an ECU, loom and car battery to bug test the whole thing...
I guess I'll find out soon as I've got my new laptop due for delivery today
Wingers
Wingers
If it doesn't work, you could always run a VM containing XP
OK. It's good to know that that might be a solution if I can't get Windws 8 to work. I have to admit I'm not great when it comes to computer systems however so will probably get someone else involved to do the hard bits.
Cheers for the idea though.
Wingers
Wingers
00 Clio 172
05 WRX PPP
00 Clio 172
05 WRX PPP
Marf wrote:If it doesn't work, you could always run a VM containing XP
This. VMWare ftw.
Loque wrote:Marf wrote:If it doesn't work, you could always run a VM containing XP
This. VMWare ftw.
Why when Hyper-V is part of Windows 8 and is a type 1 Hypervisor not an application on top of windows.
And in unrelated developments a new front runner has emerged in the Jayridium man of the year contest:
Wingers wrote: I did get as far as wandering into John Lewis and installing PCLink on one of their windows 8 display models
Haha. What do I win!
a small tin of brasso to piolish your brass neck with :-p
