Hi,
3rd/4th/5th are easy to get into, but i have to push the gear stick really hard to the left to get it into 2nd.
bearing? in the rear.
[Mk2] [Turbo] Problem getting into 2nd gear.
Re: [Mk2] [Turbo] Problem getting into 2nd gear.
What about first?
Try taking off the gear level cover and inspect the mechanisms underneath......could be a bolt thats blocking the path.
We ALL make mistakes !!!
First things first, I'd be checking...
Bushings
Square linkage of death
Gear linkages
Do you have a short shifter fitted?
Bushings
Gear linkages
Is it a turbo conversion? As it could have na gearcables not the longer turbo ones.
