Noble M500 Upgrades & Overhaul
Re: Noble M500 Upgrades & Overhaul
Peter Gidden - SBITS wrote:
MR2 Turbo Boy wrote:Ever thought about setting a Dash2 into a dash of a MR2..... :whistle:
I dare say that could be arranged......
Cool. Handy to know for when I get my race dash2 :twisted:
juliankv73
Post by juliankv73 »
OMG :shock: I was won over just by the detail on your carbon dash, the type font etc but this is the mutts big kahona's right there...,
That's so OEM, it could have come from the factory except they didn't have your attention to detail or wiring/soldering skills
Love the Stock look...makes me want to modify my Dads v6 for him just to have OEM looking trick details. That's just sublime Peter \:D/ =P~
thomp1983
Post by thomp1983 »
Excellent work peter, have you started your rear lights yet?
Danbob
Post by Danbob »
Very impressed with the TPMS integration! Very professional!
User avatar
Scott Barton
Post by Scott Barton »
=P~ Mouth watering brilliance! :clap:
Peter Gidden
Post by Peter Gidden »
Thanks for the comments guys!
thomp1983 wrote:Excellent work peter, have you started your rear lights yet?
Rear lights are going to be a major project. Going to need to make several moulds of moulds of moulds :shock: , so going to finish interior and associated jobs, plus get engine sorted.
Front clam and rear clam will be done next winter.
jakeymears
Post by jakeymears »
brilliant build, Just read the whole thread and I love the attention to detail like the brake line holders on the wishbones, on the other hand the piston clearance #-o that was scary, glad you sussed it.
Keep up the good work I'm looking forward to the updates :D
Peter Gidden
Dashboard has been flocked. Thanks to Yorkshire Flocking (who have flocked all the Ginetta dashboards) for a perfect job:
juliankv73
Oooh that's just =P~
Spot on as ever, loving the attention to details on the epic build :thumleft:
Looking good there Pete. :thumleft:
l1ca
Post by l1ca »
flocking hell that looks good!
killerferret666
Post by killerferret666 »
who you use for the flocking Pete??
was it a send it off jobby or local to you.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
juliankv73
Peter Gidden - SBITS wrote:Dashboard has been flocked. Thanks to Yorkshire Flocking
I thinks its this one :thumleft:
http://www.allfab.co.uk/yorkshireflocking/?page_id=12
Draven
Post by Draven »
Very impressive pete. As usual your attention to detail is fantastic. :thumleft:
thomp1983
Post by thomp1983 »
Peter Gidden - SBITS wrote:Thanks for the comments guys!
just can't bare to part with the last mondeo part can you?
Peter Gidden
I've not modified the thermostat housing ... yet. :D
Peter Gidden
Correct.
Speak to Mike - tell him you've seen the work he did for me. As i said above, they've done all the dashboards for Ginetta.
High quality and not expensive.
Peter Gidden
Once the dash is fitted, access to the wiring is just about impossible, so i needed to test all circuits before fitting the dash. I also wanted the centre panel totally removeable from the car for future maintenance etc.
Centre panel was wired with colour-coded wire, and all circuits, plugs and sockets etc. noted in Excel. 2 12pin plugs connect the panel to the main dash loom.
Bench testing the circuits. The 4 main switches were special order bi-colour LEDs. Green for sidelight circuit and red for switched circuits. Sidelight LEDs have now been dimmed down using an inline resistor.
Panel was plugged into the chassis mounted sockets and all circuits tested.
Then the big day. Removed gear lever (3 hours!) and carefully fitted dash. Audi air vents fitted, and gauges, Dash2 and DL1 plugged in.
Peter Gidden
Some months ago i picked up a genuine BNIB Ford GT billet gear knob. The engraved gear positions are the same as my Getrag box, and the brushed aluminium finish matches the Audi vents perfectly. Bargain at just over £100.
Gaer lever was cut down by 35mm, and thread recut to match the gear knob. Refitted along with tunnel trim.
The Lifeline extinguisher controlbox wouldn't fit where i wanted it with the side entry DIN plug.
So it was opened up, and marked for drilling.
After drilling and filing, DIN socket now fitted to rear of box.
Needed a new battery, so went for same Red Top as used in the Ginetta race cars.
Smaller than my old Odyssey and 2.5Kg lighter!
2mad
Post by 2mad »
Splendid stuff Pete :thumleft:
