crank but won't start
miib14
Post by miib14 »
Hi guys,
Got a problem with car, the car cranks but won't start.
Fuel is there and there's a spark, no immobiliser
its a rev 3 3sge btw
I tried starting it this morning and it started for afew seconds but then stalled and now it won't start at all..
So I thought I may have flooded it with fuel, pulled the plugs out and wiped them down and put them back in and it started again for afew seconds but stalled..
It won't start
Dunno what to do
Any help?
Peter Gidden
Re: crank but won't start
Post by Peter Gidden »
miib14 wrote:Fuel is there and there's a spark
How have you determined you have fuel and spark?
When was it last driven?
miib14
Post by miib14 »
Yes there's a spark, and I can Definetly smell fuel
It was driven last on Friday
miib14
Post by miib14 »
miib14
Post by miib14 »
miib14
Post by miib14 »
miib14
Post by miib14 »
Rsfudge
Post by Rsfudge »
I had this problem with mine, sounds like a wet coil. Pull the leads an connections off, wd-40 and it will fire up, I'm sure of it. I got my car cheap because if that, replaced the usual thing then discovered it was that!
Steve-O 2007
Post by Steve-O 2007 »
cheap all the earth connections as well especailly the one under the inlet manifold..
