Is the 3sfe spring that supports the boot when you open it a different pressure rating to one from a later car with a spoiler?
The reason I ask is because when I changed from a factory spoiler to aftermarket the aftermarket one was considerably lighter and the spring pushed the boot up.
I now have no spoiler on my car and no spring but would ideally like to have one because it's a right pain in the ar$e holding the boot open all the time!
boot lifter spring pressure.
Re: boot lifter spring pressure.
jack-p wrote:Is the 3sfe spring that supports the boot when you open it a different pressure rating to one from a later car with a spoiler?
Yes.
yes it has a lower pressure spring to compensate for the lack of weight of a spoiler on the 3SFE.
I've no spoiler on my car, and just removed the boot spring to avoid the boot lid flying open when the lever is pulled.
Peter Gidden - SBITS wrote:
Yes.
Thought as much, better keep an eye out for a 3sfe breaking then.
I did the same but I'm getting a little sick of holding the boot open with my head so I can get both hands in!
yeah that's what I do
Try TCB, I'm sure that's where I got mine from when I despoiled.
R
R
