inside the car remove the rear plastic cover from beneath the seatbelt, then unbolt the seatbelt reel
(two nuts).
behind that your see a nut in line with the rub strip
(outside the car), i think its about 12mm, remove this and thats one half of the rub strip removed.
the other half of the rub strip is removed by a bolt inside the rear wheel arch
(again in line with the rub strip,
with these off, remove the rub strip and the vent then pulss away
