Be aware that if you use spacers you can expect to have to replace wheel bearings
(particularly at the rear) within a few years.
That said you could certainly add 20mm without rubbing issues but 25mm might be close.
I run a 15x7 rear with a 225/50/15
(so the same as standard) but with a 35 offset rather than the standard 45.
In other words it sits 10mm further out than stock.
To that I've added a 15mm H&R hubcentric spacer and the wheel is almost flush with bodywork and indeed used to catch on arches before they were rolled
(granted though it is lowered an inch and a half).
Plenty of pictures of
'flushness' in my garage.
R.
