[Mk2] [Turbo] shark fin aerial reception
Ok so fitted one of these as my other aerial is missing and the windscreen one is no giod. So its all fitted and the reception is ok but there is a constant crackling (this is in am and fm modes). But then when I touch the thread that comes through the roof and leave my finger on it, the reception is crystal clear. could it be an earthing issue, I scratched away some of the paint on the inside of the roof. Could something be touching where it shouldn't?
Re: [Mk2] [Turbo] shark fin aerial reception
Did the aerial include a reception booster? If not then that would probably sort the reception issue.
I do have one seperatly which I tried to no avail. If I use myself as earth the reception is perfect I've also tried a different mast which does the same so I know the shark fin is fine and I know they have a reputation for being naff. Is there something I'm missing?
Try bolting a thickish (~ 3mm) bit of steel onto the mounting lugs from the sharkfin on the inside of the roof.
