[Mk2] [Generic] v6 flywheel
V6? V8? TDI? Discussion and technical advice for engine transplants inc. 5SFE & 5SGTE builds. Not for N/A to Turbo, or Rev1/2 to 3+ conversions.
Project and build threads welcome.
mk2mattw
Post by mk2mattw »
i currently have a 1mz v6 with a jun racing na flywheel, in the future i will be fitting a turbo box (as it has lsd) was just wondering is there a way i can keep the flywheel and just fit a turbo clutch friction plate?
reason for asking is i have a exedy clutch and flywheel setup that is £900 new but need to free up some cash without crippling me in the longrun
Peter Gidden
Re: [Mk2] [Generic] v6 flywheel
Post by Peter Gidden »
mk2mattw wrote:i currently have a 1mz v6 with a jun racing na flywheel, in the future i will be fitting a turbo box (as it has lsd) was just wondering is there a way i can keep the flywheel and just fit a turbo clutch friction plate?
Are you currently using a turbo pressure plate?
mk2mattw
Post by mk2mattw »
no im using a techniclutch fast road pressure plate and a 6 puck clutch friction plate
Peter Gidden
mk2mattw wrote:no im using a techniclutch fast road pressure plate and a 6 puck clutch friction plate
Turbo or N/A pressure plate? A hybrid clutch is a common fitment on V6 conversions.
mk2mattw
Post by mk2mattw »
The clutch is all Na fitment Na pressure plate and friction plate,basically what I'm hoping to do is just fit a turbo friction plate but not sure if that will fit with the Na pressure plate
jack-p
Post by jack-p »
If you fit an lsd out of the mk3 into the na gearbox wont this solve your problem?
Peter Gidden
jack-p wrote:If you fit an lsd out of the mk3 into the na gearbox wont this solve your problem?
And E153 gearbox is too heavy and wrong ratios for the V6. Will need turbo hubs as well.
mk2mattw
Post by mk2mattw »
Didnt know about this!!!how easy is it to fit the mk3 LSD?any guides about?only bought the turbo car for the box!haha
Peter Gidden
I'm building one for KarlBristol next week. 1ZZ LSD and Avensis 5th gear.
Do some searching on Google. There are some guides.
mk2mattw
Post by mk2mattw »
Thanks that's a great help!:) do you by any chance know if I can use the turbo disi cap on my Na(you replied to another post of mine)
And how much do turbo gearboxes go for these days?
Peter Gidden
mk2mattw wrote:do you by any chance know if I can use the turbo disi cap on my n/a?
Rev2 Turbo dist. cap will fit Rev2-5 Turbo and Rev2 N/A.
mk2mattw wrote:And how much do turbo gearboxes go for these days?
Depends. If a Rev3 LSD box and in perfect working order, £350-£400.
mk2mattw
Post by mk2mattw »
Sods law!its rev 2 turbo cap going on a rev4:(
So would £250 for a rev2 be about right?
Peter Gidden
mk2mattw wrote:So would £250 for a rev2 be about right?
If its good in all respects, yes.
mk2mattw
Post by mk2mattw »
thanks for the help/advise!
Return to “MR2 Engine Swaps”
