just bought my first and its quality, after having a n/a for years, needs a bit of work though... got rattling from the front and back, im guessing the droplinks
the guy i bought it from said the engine is a recon bla bla bla with a sketchy looking receipt but it looks near enough
im located in Forth 10 miles from Lanark and 12 miles from Livingston in south lanarkshire is there any mr2 specialists near me i can drop her off for them to have a look?
whats the first mods i should do for more power, im looking for 300-320bhp
also not sure which revision it is, its not got much history, says its manufactured in 2000 which i doubt, ill post pics 2morrow its got cruise control and ac ( the nob for temp is loose ish doesnt seem to adjust the temp)
[Mk2] [Turbo] my first tubby
Re: [Mk2] [Turbo] my first tubby
What revision is it? What year?
edited defo rev 3+ tho... i recon
dylan5084 wrote:edited
Pics of car, and engine would be cool, then mod path can be determined
will get em up tomorrow, when did they start putting cruise on them? also the steering wheel has an airbag if that helps?
dylan5084 wrote:will get em up tomorrow, when did they start putting cruise on them? also the steering wheel has an airbag if that helps?
Airbag steering wheel on a turbo, sounds like a rev4. Is there a passenger side air bag in the dash?
no airbag in the dash, has got a misfire when cold heres some pics! looks like its been sitting somewhere rusting its life away underneath too
oh yea and the oil is half way up the dipstick, i recon half the engine side of the dip stick tubes missing?where do i get one of those? see pic, the end of the tube is down by the turbo
have got oil leaks too
Revision 2!
Revision 3+ back lights though. Toblerones on the front mean it's not rev4 or rev 5. Clear lights on the front were rev4+ but a common swap. But Sonic Shadow was a rev4+ colour, I think! Engine transplants and bodywork swaps are all common easy done things, so who knows.
Could be a swapped spoiler and steering wheel but it seems unlikely... Original reg. plate or VIN number useful for correct identification of age/year.
i thought the front brakes were bigger on my old rev 3 but wasnt sure :/ its down as manufactured in 2000, no chance, where would i get the vin number?
sw200085304
Revision 2
December 1991 to November 1993
Chassis 059266 to 087385
xxxx ive been had then, thought i got a good deal too, paid £1800. needs lots of work too.
is that a rev 3 engine in there though? has had a refurbed engine at one point allegedly
dylan5084 wrote:is that a rev 3 engine in there though? has had a refurbed engine at one point allegedly
It has a Rev2 engine. AFM and 2 vac hoses on top of throttle body.
Dipstick should be bolted via a single M8 bolt to thermostat housing - large alloy housing that is connected to the large water hose in your picture.
Just so you're aware, that airbag steering wheel wasnt standard, so it will NOT go off in a crash.
you say it has cruise control, I can see that on the steering wheel (part of the wheel) but surely you've tested it? and it doesnt work either..
rev3turbo wrote:Just so you're aware, that airbag steering wheel wasnt standard, so it will NOT go off in a crash.
I wouldn't be driving around with an unnecessary explosive device right in front of me.
I suspect insurance company would not be happy if declared as a modification (which of course you should do, as with all modifications.)
rev3turbo wrote:and it doesnt work either..
How do you know?
you know what, looking at that it has the cruise control actuator box in the engine bay.
Th standard cruise stalk goes through the cowling of the column, so whether thats been adapted to the steering wheel contol, who knows
it could work
it could work
cruise control works fine, ive got a momo steering wheel im gonna put on it anyway
[quote=
Dipstick should be bolted via a single M8 bolt to thermostat housing - large alloy housing that is connected to the large water hose in your picture.[/quote]
im not quite sure i understand is mine wrong?
Sell me your cruise control system. Now please.
Is it not an n.a with a turbo motor?
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
