[FINALIZED] Rev 3 3vz-fe ibis white, 98k - Carlisle.
Hello all.
Price is £2800.
Due to a severe change in circumstances, I am having to let a car go. The mr2 was the last one in, so it's going to be the first one out
Rather than try to list everything the car has had done, I will use text from the advert which I purchased the car from.
The changes I have made have been to replace the tinted tail lights to original rev 3 items, add a rev 4 steering wheel, a black leather TRD gear knob, and service it too.
Also, it was MOT'd around feb time, but I could re-do it if a buyer wishes. Aswell as this, I will re-tax it for 6 months for the full asking price.
The bad points, to begin - surface rust to the left hand sill; this will be rectified before any sale for the asking price.
Mileage now sits at 98600.
Everything you read below is from the original advert.
Toyota Mr2 MK2 3VZ-FE
Rev 3 N/A Import, Tin top.
It started life as a 3SGE Rev 3 import, purchased from Barronmr.
The engine was then removed and I then began a 3VZ-FE conversion, the list of parts below speaks for itself, there has been no expense spared.
The aim for the car was to have reliable V6 close to turbo power without the surge of torque as the turbo spools. Everything has been aimed at making the car good for fast road and occasional track use.
Whilst underway with the conversion there were a few questionable points on the body work, I then decided to have a full respray.
Lots of history and receipts from initial registration in Japan.
Engine & Transmission
Toyota Camry 3VZ-FE, removed from a 1993 UK car.
Timing belt, tensioners and genuine water pump.
Head gaskets replaced, along with all other gaskets.
New HT leads, rotor arm, distributor and NGK iridium plugs,
EGR removed and throttle body coolant line re-routed.
4V6 Engine Mount, all engine mounts re-built solid at a local rubber engineers with shore 75.
Setrab oil cooler mounted in stock intercooler position, oil filter re-located and also fully swagged PTFE lines all with AN10 fittings.
Silicon Hoses throughout with Kevlar lined fuel pipe. Also oil breathers fed into an oil catch can
Mongoose turbo back box.
Standard turbo back box fitted for ¼ mile videos and also on dyno.
Walboro 255lph fuel pump
FPR
HKS Mushroom air filter with HKS adaptor plate.
Millers CFS 10W40 engine oil. Replaced every 2K-3K miles
Halfords Advanced Anti-Freeze (pink).
E153 Rev 3 LSD Gearbox with Millers synthetic oil.
Turbo Hubs and Shafts, new wheels bearings fitted.
Modified and lightened fidanza turbo flywheel (4.2Kgs)
Five puck cerametallic clutch and up rated pressure plate with OEM Toyota release bearing.
New OEM Toyota supported driveshaft carrier bearing.
Interior
Half leather and suede seats, with matching door cards.
TRD clock dials.
Short shift kit with solid shifter bushes.
Oil temp and oil pressure gauge
Innovate MT-X wide band
Sony CD player
Pioneer 6x9's behind the seats and JBL GTO-507 Speakers in the doors and original tweeters.
Aerial relocated, blade type used.
Leather Gear Gator
Leather Handbrake Cover
Exterior
Full respray in Audi Ibis White, with multiple coats of lacquer.
Always garaged and polished weekly with only Auto-Glym products.
Smoothed scuttle panel, smoothed rear light centre panel.
Turbo Engine Lid, with a gas strut.
Rev 1 spoiler, aerial removed and side pod smoothed. Smoothed wing mirrors, de-badged at the rear.
Wheels and Tyres
Manaray Split Rims, Front 8JJx17, Rear 9.5JJx17. ET45
New Maxxis MA-Z1 Victra 215/40/17, 235/40/17. (8mm tread front and rear, 1 month old)
Suspension and Braking
Bilstein B6 yellow dampers with Eibach Springs (-30mm), new drop links and top mounts all round.
Tein front strut brace.
Re-furbished rev 3 callipers with EBC yellow stuff pads,
Braided Do-luck lines
Castrol SRF-660 fluid.
Rear sub frame strengthened, shot blasted and sprayed.
Recent four wheel alignment, after new tyres fitted.
Here is a link to my photo bucket with photos on - http://s277.photobucket.com/albums/kk53/sturobinson88/
Some photos -
I urge anybody who is genuinely interested to come and see the car for yourself. It is in Carlisle. My mobile number is 07920 787447.
Price is £2800.
FPR
Interior
TRD clock dials.
Sony CD player
Leather Gear Gator
Exterior
Wheels and Tyres
Some photos -
Last edited by StuRobinson88 on Sat Nov 03, 2012 5:37 pm, edited 3 times in total.
Superbia in Proelio.
Current: Jaguar XJ12 Series 3, GSX-R 600, 1972 Mini 1000.
Past: Clio 200 RS, ST185 GT4, Rev 1 n/a, Escort S1 RST, Mini Clubman, Mini Mayfair, MR2 V6, MR2 n/a.
Cars of shame: Rover 416, Rover 45, Rover Metro.
Re: [FINALIZED] Rev 3 3vz-fe ibis white, 98k - Carlisle.
£3200
If my Beemer sells tomorrow i could offer you £2k and a pack of fruit pastilles?
Shifty6Speed wrote:If my Beemer sells tomorrow i could offer you £2k and a pack of fruit pastilles?
Lol not quite there.... But you are welcome to come and have a look at it anyway
StuRobinson88 wrote:Shifty6Speed wrote:If my Beemer sells tomorrow i could offer you £2k and a pack of fruit pastilles?
Damn haha! Looks gorgeous, but i'm about 240 miles away and unless we have a sugery deal going on here, i can't justify come that far just to look at what i can't have lol... Looks beautiful though, just what i'm after now (my beemer just sold!) My budget is only £2500 ish though and literally not much more...
GLWTS!!!
If you'll take a deal then I may be interested too...
riot68 wrote:If you'll take a deal then I may be interested too...
Hi there.
Apologies for the delay in responding.
What kind of deal are you interested in offering?
Thanks, Stuart.
My budget only £2500 too although there's a few bit's I wouldn't need like wheels...
riot68 wrote:My budget only £2500 too although there's a few bit's I wouldn't need like wheels...
Hi mate.
I'd only knock a couple of hundred off for the wheels, tbh. And I don't have any standard items to replace them with.
You'd be best off coming to see the car.
Thanks, Stuart.
Ok, will keep you posted, got a few other I'm interested in 1st...
Price change to £3000
Do you have any pics of the rear and the new dials/interior? (oil temp/pressure)
ikarl wrote:Do you have any pics of the rear and the new dials/interior? (oil temp/pressure)
Hi there.
Thanks for the post.
I didn't realise there were no 'rear' shots of it until you asked for it.
I will get them tomorrow for you, if that's okay?
Thanks, Stuart.
brilliant, thanks
ikarl wrote:brilliant, thanks
Hi mate.
Here is a link to photobucket which I have added 3 photos of the rear end to.
Thanks, Stuart.
Stuart, you have PM
ikarl wrote:Stuart, you have PM
Hi mate.
Not received anything.
Can you try again please.
Thanks, Stuart.
Bump due to price change
Dirt cheap for what it is. Good luck bud.
I wish someone with the cash would agree it really is a brilliant car!!
