Hi everyone,
Does anyone know the correct Part Numbers for the little brackets that hold the speed flaps and the proper fender liner to go with? I purchased the speed flap/spoiler pieces that go in front of the wheel, but I would like to properly secure them, and don't want to drill any holes.
Thanks!
PN-Request: Late SW20 Front Fender Linders & Speed Flap/Spoiler Brackets
Re: PN-Request: Late SW20 Front Fender Linders & Speed Flap/Spoiler Brackets
abovetherim wrote:Will this help?
Very much so, thank you.
I had thought there was a little bracket between the flap and the liner.
I can't seem to see it in that drawing, though. Unless its 90387-07032, but it doesn't quite look like it.
The PN you listed is std part ie a nut or bolt
Here is the pn list
53161 DEFLECTOR, FRONT BUMPER STONE
53161-17010 2 33.79
53301 HOOD SUB-ASSY
53301-17060 1 442.46
53301B CUSHION, HOOD BUMPER
90541-15111 4 2.65
53361 WEATHERSTRIP, HOOD
53361-17010 1 142.81
53736F SEAL, FRONT FENDER APRON, RH
53736-17010 1 53.73
53737H SEAL, FRONT FENDER APRON, LH
53737-17010 1 48.50
53801 FENDER SUB-ASSY, FRONT RH
53801-17100 1 216.27
53802 FENDER SUB-ASSY, FRONT LH
53802-17080 1 216.27
53827B PROTECTOR, FRONT FENDER SIDE PANEL
53827-17020 1 8.33
53828B PROTECTOR, FRONT FENDER SIDE PANEL, LH
53828-17020 1 8.33
53875A LINER, FRONT FENDER, RH
53805-17010 (12/1997 - ) 1 79.61
53875-17030 (07/1995 - 11/1997) 1 79.61
53876A LINER, FRONT FENDER, LH
53806-17010 (12/1997 - ) 1 79.61
53876-17030 (07/1995 - 11/1997) 1 79.61
53878C SPACER, FRONT FENDER
53878-14020 2 6.46
53879A RETAINER, FRONT FENDER LINER
53879-14010 4 1.97
58369D BRACKET, FUEL TUBE, NO.3
58369-32010 2 5.01
Here is the pn list
53161-17010 2 33.79
53301 HOOD SUB-ASSY
90541-15111 4 2.65
53736-17010 1 53.73
53737-17010 1 48.50
53827-17020 1 8.33
53828-17020 1 8.33
53878-14020 2 6.46
53879-14010 4 1.97
58369-32010 2 5.01
Or you could just buy the flaps and 6 nuts/bolts and drill (very easy) the original arch liners and bolt them on. Really isnt worth going to the trouble and great expense of buying the arch liners, theyre exactly the same as earlier ones just without the 3 holes in them
ryan wrote:Or you could just buy the flaps and 6 nuts/bolts and drill (very easy) the original arch liners and bolt them on. Really isnt worth going to the trouble and great expense of buying the arch liners, theyre exactly the same as earlier ones just without the 3 holes in them
+1
Of course, I could, but I'm interested in doing it properly
Is it beneficial to have a speed flaps? Will I feel anything at high speeds?
If it is, I am going to cut some plastic and fit them. The car will be mostly used for the track.
I never noticed and improvement after fitting but then again, I didnt spend £150+ on the 'proper' rev 5 arch liners with the special 3 holes pre drilled
I just marked and drilled six 4mm holes and they were fitted in no time
Jesus, what's the big deal if I've decided that I want to buy the parts? I'm not saying everyone else has to, or even that it's in some was better than drilling holes. Thanks to abovetherim for actually coming to my thread to help.
dj_Twin_turbo wrote:Jesus, what's the big deal if I've decided that I want to buy the parts? I'm not saying everyone else has to, or even that it's in some was better than drilling holes. Thanks to abovetherim for actually coming to my thread to help.
Chill out, was just trying to save you some money. I will make sure I dont answer or partake in any of your future posts
ryan wrote:Chill out, was just trying to save you some money. I will make sure I dont answer or partake in any of your future posts
Sounds good, I won't miss the sarcastic jabs. As evidenced by my first post, I am well aware that drilling is an option.
