Hi mate
(front clears)
I haven't got it on me at the mo, but it shows you how to in the manual
(iro changing bulbs).
From memory your right flat screwdriver, also worth wrapping a thin piece of material round it just incase.
They come out pretty easy, apparently Mr T used various different connectors though and you never know quite what you are going to get, JDM, UK makes no difference they seemed to use whatever the factory had at the time.
Mine were 3 circular connections in a row and its a UK Rev 3 which
'should' have T shape, friends was the same.
Take its easy and will be fine, they push back in in 2 secs
Rob
