Hi
I found this unconnected connector under neath the steering wheel while fitting audio system.
my car is a rev5 turbo, it didn't come with dash lights dimmer switch, could this be the connection for it?
It looks like it should connect to a switch where the fog lights are,
http://www.puredream.net/mr2/connector/
any ideas?
Thanks,
Tony
[Mk2] [Turbo] Can you identify this connector?
Re: [Mk2] [Turbo] Can you identify this connector?
My rev3 turbo also had this. Not entirely sure but I think it is the front foglight loom for cars without the steering fogs option.
