Just wondering what realistic numbers i will be looking at after some more tuning!
Currently at 500fwhp / 422lbft at 1.55bar, only stopped tuning due to fuel pump going bad. The turbo i am using is the HTA version of a GT3582r which uses a anti surge housing and billet compressor wheel, like the GTX35r. 0.82ar exhaust side. I believe the standard GT35r's most efficient between 1.6~2.4bar iirc? and the HTA having the billet compressor -lighter and more surface area on the fins, is most effective between 2bar ~ 3bar ! Im hoping to get the boost up to atleast 2bar so it will put the turbo just inside its effeciency range and should produce a lot more power going from1.55 to 2bar than it did going from 1bar to 1.55 ?? thats the theory anyway. Engine is a 2.14L rev3, std cams and we will be retarding the exhaust cam slightly. My current IAT's are maxing at 41'c on dyno.
Also current tune is on BKR7E's, have gone a grade cooler for this next tune.
am i being over optimistic by hoping for a 100bhp increase?
whats everyone elses guesses... torque figures too
Dyno coming up..Guess my HP
Re: Dyno coming up..Guess my HP
I didn't understand much that but I'm going to have a guess at 578fwhp / 456lbft
Hope it all goes well for you
578fwhp
What do I win?
What do I win?
97fwhp after the "hundred shot of NOS blows the welds on the intake!"
Had to fit a Fast and Furious quote in there lol
Im going to go with 597fwhp
haha sweet.. guess ill make sure Ryan double clutches on the dyno like hes supposed to then
well the winner gets....... 1 billion Lactospore Probiotics
Psummers, see ur in maidstone,only down the road from me..not seen you about before!?
510whp
Good luck, lets see you run 2.5+bar through it and make closer to 600whp
2.5 bar would be nice! im not setting any limit to how far we will go, well unless it starts getting stupid! see how it goes on the day.
V-power is the fuel of choice, no WI. believe it was chris who made 600fwhp on a normal 35r, vpower and a stock head?
StevieL wrote:578fwhp
What do I win?
I guessed 578 first!
Pick another random number
RyanRs wrote:Psummers, see ur in maidstone,only down the road from me..not seen you about before!?
I see quite a few MR2s around in Maidstone, haven't seen yours about though. I keep meaning to go to a Kent meet but I'm always busy
Lol these aren't supposed to be random guesses! more educated predictions given specs and compared to previous builds!!
Psummers, i been about for like 6 years lol. but then again, most people hear me but dont see me
psummers wrote:StevieL wrote:578fwhp
What do I win?
I never even noticed that, sorry
623fwhp
And your compression ratio is?
Will you be using some Halfords Octane Booster???????
dyno
I think ryan will stop you from running to much boost on road fuel.
id guess 560bhp at circa 2.1bar ,unless you raise your octane and get to run 2.5bar with plenty of ignition then you may get what you said
when are you booked in for?
why don't you smack a Meth injection system on it?? (Or if Dog the Bounty Hunter was a car tuner, an ICE injection system )
Yes i do believe he will limit it also, i would like to avoid the requirement of WI if possable as i have intentions to use nitrous at the low rpms to aid turbo spool and using WI aswell will make things a little too complicated. i was thinking of mixing an alcohol blend with the fuel perhaps?
RyanRs wrote:as i have intentions to use nitrous at the low rpms
just watch them intake welds ffs
RyanRs wrote:i was thinking of mixing an alcohol blend with the fuel perhaps?
I recall reading that this doesn't work too well as they tend to separate in your tank instead of staying mixed...
Steve-O 2007 wrote:RyanRs wrote:as i have intentions to use nitrous at the low rpms
Make sure that floor plate is screwed in securely!!
Ahhh... good times
