that must have been a scary moment, and under the wrong road conditions
It should be almost impossible for an ABS unit to malfunction in that way.
.brakes are safety critical items and go through quite severe failure mode analysis during design.
Sometimes you can get a sticking piston that will seize the brake on to that wheel although I've never experienced it to be an
'emergency stop' level of braking.
End result is pads smoking and disc, caliper and hub seriously hot.
.but, when it all cools down the piston has freed itself.
I had exactly this today driving up the M5, the NS front stuck a little and it got worse the longer I drove for obvious reasons.
Then after parking on the drive for an hour the piston has released
