I haven't posted here in a while but a little update from my side of the pond.
My BBK is done, sorta by 90% since i have to build a new hand brake union. but it's now here and staying here.
Rear
-MK3 Supra shaft an outer CV custom cut by CRW (thanks josh)
-MK4 Supra TT rear rotors (324x18mm)
-LS430 Rear caliper
-LS430 324D Custom bracket (by me)
-Secret drum assembly
More info on it here
http://www.mr2.com/forums/show-off/Toyo ... tup-3.html
[Mk2] [Generic] Can you Supra size it?
Re: [Mk2] [Generic] Can you Supra size it?
nice work bud and a decent handbrake (e-brake to you yanks ) to ! I love the fact it's all Toyota parts rather than the mix of Mazda / Porsche parts I have (and that crap OEM rear caliper). Been a long time coming, good work
think you missed a bit mate when you copied and pasted
(whats the spec of the fronts?)
Front is a LS430 caliper and LS400 rotor (315x28) but im building a proper bracket to use the proper LS430 rotor (315x30) which is thicker.
i assume you are using custom brackets on the front as well?
is there a reason why you're not using the supra 325x30 mm front disc?
it complicates the front mount drastically, personally i was going to run a double stagger wheel setup and the ls430 fits right under 16"
oteck wrote:it complicates the front mount drastically, personally i was going to run a double stagger wheel setup and the ls430 fits right under 16"
yep the 325mm disc stuffs 16" wheels for sure!
it was the plan at the time but later found out there isn't a single 16" wheel that will clear the rotor thats in my style. i think i've added enough weight so lets not use the supra tt front
